attaching bt3000 to a HTC mobile base
  • Creaton
    • Feb 2010
    • 19
    I'm trying to figure out how to attach a HTC 2000 mobile base to the bottom of my bt3000 base. First is the issue that two legs with height adjusters are shorter than the other two legs. And also how to bold or fasten the HTC base to the bt3000 base by bolting, screwing, etc.
    Any suggestions, and or pictures would be greatly appreciated.
    my BT3000 just sits on the HTC base.
    the HTC base also has some adjustments. Between the two you can make your saw level and non-rocking.
    With the two lift levers, there will be a point when the HTC base is twisted and the BT3 rocking but this will pass when you get the seond lever lifted.
    Don't overthink it, its just a mobile base.
    • Creaton
      • Feb 2010
      • 19
      I did end up being easier than I thought, but ended up attaching the saw base to the mobile base using the threaded holes in the saw based used for the leveling legs. Now enjoying my new found BT3000 mobility!
