BT3000 Motor Size
  • econn
    BT3000 Motor Size
    I bought a BT3000 in 1993. Yesterday the motor stopped. I believe it's a brush problem and I want to order new brushes, but I don't know whether I have 13 amp motor or a 15 amp motor. How do I make this determination by looking at the motor? Thanks for your help.
  • tjr
    • Oct 2008
    • 167
    • at the falls of the Ohio
    • BT3000 (1 3/4 of them)
    There should be a plate on the right side of the saw near the outlet where the saw plugs into the switch that shows serial number and amps.
      Welcome econn!
      I can't help on the ID, but if you don't already have the BT3 FAQ you should send a PM to Loring. Check his sig or profile: LCHIEN
      There's a wealth of info in those pages.
      • eezlock
        • 997
        • Charlotte,N.C.
        Bt3000 motor size
        If my memory serves me right, the BT3000 has a 13 amp motor, the BT3100,
        has a 15 amp motor. I may be wrong, but I'm pretty sure I'm right!
          Not quite... IIRC, early BT3000's had the 13-amp, but the 15-amp motor was added after a couple of years. All BT3100's had 15-amp motors.
            • 22034
            most BT3000s had 15A motors but the very early ones like 1993 (first year of production) were the ones with the 13A motors.
            They made the BT3000 from about 1993 to 2001? and only the first 1 or 1-1/2 years had the 13A motor, the rest had 15A.
            You can tell for sure by checking the name plate, it should list the amps, with 13 or 15 depending on the motor.
            I have heard its hard to get the brushes for the 13A motors and even some of the early 15A motors - you may need to buy some carbon brush material and make your own.
            • reddog552
              • Dec 2006
              • 245
              • Belleville Il.
              • Bt3000
              Early Bt 3000
              The early 13 amp. motors have a plastic extrusion on them.
              The bitterness of poor quality lingers long after the sweetness of low cost is forgotten!
