Bt3 faq 4.9
    • 22074
    Bt3 faq 4.9
    I jumped the version up because someone pointed out to me that the hyperlinking in the file did not work. I fixed it and resent it to the people who got the 4.8 version that had the problem.
  • pbui3057
    • Jul 2008
    • 114
    • Mather, CA
    What are some of the new updates in comparison to v4.6?
      • 22074
      i did not keep a change log. i suppose i could run diff programs on the Word files but i don't feel like its worth the effort.
      4.9 fixes 4.8 which had hyperlinking problems, 4.8 was just minor changes over 4.7 the big changes came around 4.0-4.5 which were the days of bt3100 going out of production and 21829 coming into play.
      Its really intended more as an answer document rather than a manual so if the answer is up to date then that's what counts.
      I try to keep up with the issues and new solutions to questions that appear multiple times (hence the frequent part) so its a compendium of the knowledge that has passed thru BT3central.
        For those that don't know, does 4.9 answer the FAQ of "What does compendium mean?
          You "resent it" to the people...??? Your Freudian slip is showing, Loring...
