After several years of lurking and wrestling with what to get (BT3K or Bosch 4100) I finally picked up a BT3100 for $70. It needs a little work. Here are the issues and a few questions:
Here are the questions:
Thanks for the help. This is a great forum and one of the reasons I went for the BT3K.
- The miter fence and blade guard/riving knife assembly are missing.
- The "bottom" (?) half of two of the miter table slides are missing.
- The elevation is not real smooth (it takes higher effort than I expected), even after cleaning and lubing the mechanism with a silicone spray. The shims and their sliding surfaces look OK, no galling. The elevation lead screw looks OK also. Can't see the threaded bushing on the motor. The bevel gears seem kind of sloppy.
- The throat plate has about a 1/2" wide slot and mounts with one screw and two fingers that slide under capture screws. Is this the stock version?
- Will the Sears 21829 miter fence asssembly work on the BT3100? It's available as an assembly for the 21829 at a better price versus the individual parts for the 22811.
- Should I get a complete set of 4 miter table slides? Two appear to be OK.
- Any suggestions for the elevation mechanism? Alternate lubricants?
- Any throat plate recommendations to get started? I just need something basic.
