The shim problem has been fixed and the saw is back together again. While I had it apart, I took some time to make sure I cleaned everything I could get my hands on and lube anything else that moved.
That all being said, I am thinking about mounting a router to the BT3000. I know there was a router mounting bracket system available but has anyone mounted a router with a homemade option? I have a Craftsman router table that I've had for a while but it takes up a little more space than I would like, so I thought I would just use the saw for all it is worth.
Thanks for all the help and write-ups on shims replacement, it really helped out.
Dave
Dave
