dado blade
    On a slight tangent:
    I needed an odd-sized dado the other day. I did it in two cuts. The first cut was slightly undersized. I used the micro-positioner on my fence to get the exact width I needed. Worked like a charm.
    I use an 8" stack. I forget which brand.
      • 22098
      Originally posted by dbhost
      So what do you do for undersize ply?
      well, if the ply is 15/32 (nominal 1/2")
      then I will take 14/32ths (7/16") as 2 outer blades + one 1/8 chipper + one 1/16th chipper and then add 1/32" worth of shims which would be .030" total or three .010 shims spread out amongst the chippers.
      that is left to right,
      arbor washer, left blade, shim, 1/8 chipper, shim, 1/16th chipper, shim, right blade, arbor washer.
      I have not made any dadoes for plywood recently, all my dadoes I can recall have been 1/4. 3/8 or standard fractions for the most part. Besides, there's no standard plywood thicknesses, shims are likely to be used anyway.
        FWIW I just came back from my local rockler and they have the 6" rockler on special for $54 YMMV.
        • esbit
          • Jun 2009
          • 7
          I just picked up a new set of Freud 6" for $25 at a sale. Im doing tendon work in oak .
          Dan
            That's not a bad price.
