16 year old BT3K Back in Action
  • Jim Frye
    • 1348
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    A couple of weeks ago, while I was finishing a bed step for my grandaughter, a shim became stuck and the blade would not retract. Yesterday, I decided that it was time to do a complete tear down maintenance on this saw. After all, it was very early production model and hasn't been apart in nearly 14 years, so I went at it with gusto. The offending shim has been slipping around for over a decade, but never caused any problems, so I left it until it did. Once apart, I found a couple of interesting tid bits.
    When I took the old shims out, there were areas of packed saw dust that had gotten between the shims and the aluminum slide areas of the locker bracket.
    The original shims had been tacked in place with some small deposits of what looks like silicone. I used the same idea when I put the new ones in place and let it cure before reassembling things. This made the reassembly a piece of cake.
    The belts were in like new condition, so the two extra sets I bought many years ago went back in the parts box.
    The motor brushes are less than half worn, so I didn't need replacements for those either. There was almost no dust inside the motor. I firmly believe this is due to the way I have the cabinet enclosed and that I always run the saw with the shop vac connected.
    Before I bolted the locker bracket back together, I made up a paste of powered graphite dust and mineral spirits. I liberally brushed this paste on all of the aluminum slide surfaces and on the shims where they would contact the locker bracket. I also brushed this paste on the elevation screw shaft. I let this paste dry completely overnight before reassembling things. The locker bracket slips up and down with almost no effort now.
    Jim Frye
    The Nut in the Cellar.
    Good for you! Take care of the old girl, and she'll thank you for it...
    • Mr__Bill
      • 2096
      • Tacoma, WA
      Has anyone tried "Anti-Seize" for this? (It's the alum. looking stuff used on break pads to keep them sliding on the caliper) Mine is starting to be a little hard to lower and I was thinking about fixing it.
      Bill,
      Happy whatever holiday you celebrate this weekend
        Glad to see you finally got out of bed, Jim. Mine also has some years on it, without problems. Keeping my fingers crossed.
          • 8786
          Jim, when are you going to get out of the cellar?
          • Jim Frye
            • 1348
            • Maumee, OH, USA.
            Probably never. I will be retired in June and it looks like we are staying in the house we own until we croak. At least its paid for. The cellar too.
            Jim Frye
              Glad to hear it is still running after 16 years. You should stop by here more often.
                • 9540
                Jim,
                FWIW, when I was looking for my first table saw, and came across yoru articles online... UNFORTUNATELY I didn't know quite enough to avoid the BTS21 first off... I had the BTS21 confused with the 21829...
                Your articles helped me pick up and mod my BT3100, and gave me some great ideas for a mobile cabinet. (Spurred on very recently by Poolhound.)
                Hopefully you will drop back in here more often... I could use more articles like the ones you have put up...
                  Let us know how the graphite paste holds up. The PTFE based sprays work, but not for very long.
                  • Jim Frye
                    • 1348
                    • Maumee, OH, USA.
                    graphite paste
                    I have been using dry graphite powder on this saw since it was new. The elevation mechanism is still not worn, so I would say the powder works fine. I made the paste up only as a transport method. The paste allows me to concentrate the graphite much more than simply puffing it in place. The mineral spirits evaporates completely within a few hours and leaves the dry graphite where it was deposited. The paste method will also allow me to lube the shims and the elevation screw more easily without having to open something up.
                    Jim Frye
                    • Dickl12
                      Handtools only
                      • Jun 2008
                      • 3
                      Graphite & Solvent
                      Try "lockese" it is graphite in a solvent. I have found the solvent allows the graphite to flow into the cracks, then drys off. Locksmith and Hardware stores at the Key Maker machine should have it.
