Well, I finally picked up a BT3000. I've been looking for a while and found one posted in the BT3central classifieds!
Now, every saw I have seen posted on CL, etc is always described as hardly used or lightly used, but in reality, this is hardly ever the case (I looked at 3 BT3100s in very rough shape). So when then seller told me that this saw was never used, I was skeptical. But after an inspection I'm pretty sure he was telling the truth. There was not a grain of sawdust on it. There were no scratches or marks or any indication that the saw was ever turned on. It was fully assembled (except for RK), but it had never been aligned. I turned it on, and it ran. So I came home with a pristine saw.
So my question to the forum is this: What sort of maintenance should I do on this 8-year-old never-used saw?
I'm pretty sure the shims are in place, but what sort of damage does sitting idle for 8 years do to the belts? Should anything be lubed or cleaned. It was stored in a dry basement, but should I inspect any specific parts for corrosion?
This forum has been tremendously helpful so far. Any suggestions will be appreciated.
CD
CD
LCHIEN
. I tried to push it back into place, but it does not want to move, and I do not want to force it. The other shim is sliding down, but can be pushed back up into position.
