My sliding miter is properly aligned and is set correctly to zero but when I go to 45 it is about 5 degrees off. Any idea why or what I'm doing wrong?
Miter angles
that's probably it, you need to read off the back edge of the orange-reddish indicator tab. you also have to have the black plastic bottom pivot in a hole (to the right is the usual choice) on the SMT.Last edited by LCHIEN; 01-11-2009, 12:28 PM.
LCHIEN
