Height locking adjustment
  • jerrbitt
    Handtools only
    • Apr 2003
    • 4
    • Jacksonville, NC, USA.
    I have the Sears equivalent of the BT3100. Recently I noticed thta even though I have the height adjustment lever pushed all the way to the left, I can still raise or lower the blade.
    So far the setting of the blade seems to stay in place but I worry after during a lot of precision cuts whether the setting might slip.
    Can't find anything in the manual about adjusting. Any ideas please?
  • RodKirby
    • 3136
    • Mao Shan TSC-10RAS
    The locking lever locks the bevel angle, NOT the height
    Don't worry - it wont move down by itself.
    It allows you to make fine height adjustments.
    Downunder ... 1" = 25.4mm
      agree with Rod K.
      BTW, the elevation adjustment is exactly 12 turns per inch. That's 0.083" per turn or
      .021" per 1/4 turn which is just over 1/64th inch.
