Runout and spacers
  • Bill Stock
    • 186
    • Canada, Eh!
    Runout and spacers
    I was getting some poor quality rips, so after some investigation I replaced the gripper on the back of my rip fence. The rips were still less than stellar, so I invested in a couple of new blades and a dial indicator to check for runout. I don't have a fixture block (yet), so I can't check the actual arbor runout. But both blades are reading about .025 of runout.
    Do the spacers contribute to the runout? There's also a good chance I've overtightened the arbor nut (bent the wrench once); whats the cure, new arbor washers?
    • 22053
    spacers are not soft material I don't think you can bend them.
    Tightening the arbor - its been stated here may times you just need a bit more than snug. If you lean on them like a gorilla you will distort the blade, washers, etc.
    what kind of blades, cheapies or good ones?
      I have had to replace arbor washers in the past for this exact same reason.
      I would suggest cleaning the ones you have thoroughly and trying them again. If you still see lots of runout...
      Put a mark on each washer. Align the marks with a mark on the blade. Measure blade runout and mark the blade for high and low readings.
      Now loosen the nut, and spin the washers 180-degrees in relation to the blade and tighten the nut again. Now measure blade runout. If the high and low readings have reversed 180-degrees, then you probably do have a problem with one or both arbor washers.
      • Bill Stock
        • 186
        • Canada, Eh!
        Both blades are Dimar, not Forrest, but SNB crap either.
        • Bill Stock
          • 186
          • Canada, Eh!
          Thanks, that's a good tip. Once I rule out the arbor I might just replace the spacers and washers.
          • cdub101
            • Jul 2007
            • 49
            Similar issue
            I have had a similar issue. Do you need to go through the manufaturer to get new arbors and spacers?
              You can try contacting the manufacturer and see if they will provide anything for free. But seeing as most of these saws should no longer be under warranty, your best bet is ordering them from m-and-d.com or sears parts website.
              BTW, the most likely point of failure would be the arbor spacers. A bent arbor is pretty unlikely.
              • Bill Stock
                • 186
                • Canada, Eh!
                M-and-D don't seem to sell the Arbor washers (TTI-69401030) and Mowtown won't ship to Canada.
                969205001 no longer seems to be available.
