My fence clamp has always seemed "difficult" - when clamping, it always took what I considered too much effort to secure the clamp, and when I did, the I could not get the handle to a "fully-down" position, and the clamp would ride up on the front rail.
After trying several things, including those recommendations from the FAQ, I could not prevent the riding up or get to fully-down, so after examining the front clamp mechanism and seeing no allowance for adjustment, I located plastic bushing that is positioned between the clamp cam and the rail (secured by two small screws in the clamp assembly), which I then removed.
This helped - but too much; the clamp moved easily to a secured, fully-down position which did lock onto the front rail, but the rear clamp would not lock to the rear rail... and adjusting the rear clamp to compensate required moving the screw in so far that I could not get the fence off the rear rail when it was unlocked.
Solution: I took the plastic bushing to my bench grinder, removed about 1/32 of the material thickness from where the cam contacts it, and reinstalled it in the fence clamp - then reset the rear clamp screw back to original position. Fence now locks smoothly and securely, front and back, handle fully-down, no ride up. (Also took a moment to recheck fence/rail/blade settings - still DNO
Has anyone has to do anything similar to get the fence clamp working properly?
. )Has anyone has to do anything similar to get the fence clamp working properly?
LCHIEN
