I'm getting set to drop an order for a Shark Guard... I bought this saw for the riving knife and as I use it more I keep catching myself wanting to not put the stock guard back on as I transition between through-cuts (ripping/crosscuts) and non-through cuts (rabbets, grooves, dadoes)... sounds like the Shark Guard where I can keep the riving knife in place is at least a partial solution. So, the question now is whether to order my new Shark Guard with pawls or without? While I recognize the potential value of the pawls, the stock ones have been enough of a PITA that they've spent most of their existence tied up out of the way with a tie-wrap
As such, if I get a SG w/o pawls, I ain't losing much. Seems like it'd be worthwhile to get them if they are an improvement (i.e. not so dang sharp/pointy and spring-powered to boot) over the OEM pawls
Who all here uses pawls on their Shark Guard? Would you change if you ordered a new one?
As such, if I get a SG w/o pawls, I ain't losing much. Seems like it'd be worthwhile to get them if they are an improvement (i.e. not so dang sharp/pointy and spring-powered to boot) over the OEM pawlsWho all here uses pawls on their Shark Guard? Would you change if you ordered a new one?
