Finger Joints
  • unclecritic
    • Feb 2008
    • 99
    • Michigan
    • Craftsman 21829, (2) bt-3100's
    Finger Joints
    Anybody ever play around with the idea of a finger joint jig that works with the smt? I havent been in front of my saw recently, so I'm not even sure of the possibilty. One of my consumers wants some storage cubes built and wants a cool looking joint.
    Lee (Stytooner) posted a Finger/Box joint jig way back when and it is occasionally referred to in different posts from time to time.
    Check this post out:
    http://www.bt3central.com/showthread...=Box+joint+jig
    I just found this - A quick jump to the specific jig that works in conjunction with the SMT table can be seen here on his site:
    http://www.leestyron.com/lynnjig.php
    • unclecritic
      • Feb 2008
      • 99
      • Michigan
      Thanks for the reply
      Man, that thing is pretty slick...
      I could bang out alot of cubes in a short amount of time with that... I think I know what I'm doing on sunday
      • rnelson0
        • Feb 2008
        • 424
        • Midlothian, VA (Richmond)
        • Firestorm FS2500TS
        I think I must be a little obtuse. How does that jig work? I didn't see any spacer to ensure that the joints are all the same width.
        • mschrank
          • Oct 2004
          • 1130
          • Hood River, OR, USA.
          I think it relys on turning the crank a specific number of times to move the carriage over.
            • 22086
            using a 3/8-16 thread per inch threaded rod, you make a cut, then turn the crank a specific number of turns. For example, for 1/4" fingers, use a 1/4" dado blade, make a cut, then turn the crank precisely 8 turns to move the carriage 1/2" (8 x 1/16th per turn) then make the next cut.
            Rinse. repeat.
            • Greg.B
              • 166
              • Joppa, Maryland
              Another easy (perhaps easier) jig to make is one where using a say 1/4" dado blade. You make a 1/4" runner out of a piece of hardwood, and glue it onto a base. As you cut the first finger, you put that on the runner and that gives you a 1/4" space, as long as the blade is a 1/4" from the runner.
              Its alot easier to do this way on a router.
