OK, folks, I have the router table mounted and own an RE 1802 router. The one that came with three bases and a sack. Well-constructed but useless sack, but oh, well. Some day I may need to go rout somewhere else. Maybe your house?
The mounting directions that came with the BT3100 accessory set, don't specifically say that that router is compatible with the RT. They mention other, similar numbers, but not 1802.
Also, I forgetfully mounted it without first removing the black sub-base (it's a three-hole mount). Thinking better of that, I'm about to go back and remove the sub-base just to be cautious. That's when I noticed that the RT was for other routers, it seems.
So am I completely wrong to use this router with the RT?
And do you really need to remove the sub-base? It's fairly thin on that model, about an eighth of an inch.
Thanks a lot.
Don.
Thanks a lot.
Don.
