Dado Blade ??
  • B Adams
    Handtools only
    • 3
    • Macungie, PA, USA.
    Dado Blade ??
    Hello, I know this may be a dumb question, but can a 8" dado be used with the BT 3100 or must you use a 6" dado set?
    William M. Adams
    • 21992
    short answer - yes a 8" can be used but with limitations.
    I'd get the 6"
    I just e-mailed you the FAQ with the long answers.
      Unless you need 3" deep dadoes, stick with a 6" set. You'll be glad you did.
        • 21992
        an 8 will only do 2.5" max, anyway. 6" will do 1.5" max. That should still be plenty deep - I've never even come close to needing that.
