Router for the 21829
  • lum
    • 32
    • Florence, OR
    • Delta. Build scrap wood with it.
    The suggestion to mount the router to a spare accessory table looks like the path to take in this case ... where I will likely need to collapse the workshop too frequently. I've used a few square feet of plywood spanning a couple of sawhorses as a router table. It was awkward to attach and remove the router from the plywood. The spare accessory table is an attractive approach.
    Thank you for the photo and the guidance, gents.
    Liam
    • dkerfoot
      • 1094
      • Holland, Michigan
      I posted this elsewhere, but I think it is worth a repeat. I have a very nice and large router table, yet sometimes prefer the table on the 21829.
      It is especially handy for routing dados that are more than a few inches from the edge. Most router tables can't handle this, but it works great on the BT3/21829 series.
      A quick recomendation: Instead of messing with the 2-peice fence that comes with it, remove the two hunks of wood and reuse the brackets for a sacrificial fence. Just attach a piece of 3/4" MDF (or any flat board) to the two brackets and connect it to the rip-fence. Use moderate care when tightening so that you don't flex the fence. Slowly push it into the bit and viola, you have a custom made, zero clearance fence.
      Of course, this lacks dust collection. The post that is intended for mounting the fairly useless bit-guard would work well for mounting a shop-vac or DC hose, but I haven't tried it myself yet.
      Doug Kerfoot
      KeyLlama.com
      • eezlock
        • 997
        • Charlotte,N.C.
        router for the 21829
        Lum, I think that you would like the router table set-up better on the 21829
        if you used a Dewalt 616 or 618 with the three base kit. Just mount the
        fixed base under the router table and leave it there, and use the other bases,
        the plunge and d-handle bases for the freehand work when needed. I used a
        sears router ( older style) under the Bt3100 table and did not like the clamp
        locking feature, it would open up during use and allow the router to change
        it's adjustment( drop down). I eventually decided to build my own router
        table cabinet and got away from the saw mounted one and I like it better.
        eezlock
