I just bought a used BT3000 on a stand and want to do something about saw dust collection. I plan to use the table saw only occasionally and only outside in the driveway, rather than inside a shop. I want to avoid the use of any type of vacuum attachment as it would be too impractical and perhaps unnecessary for occasional use outside. All of the posts I have read so far that describe custom dust collection setups, however, seem to involve the use of a vacuum (or dust collector) hose connected to the table saw.
I want to, instead, just let the dust drop down directly from the blade area into a tray (that I would install) which can then be emptied from time to time. To do this, I think I would need to remove the DUST COVER (Part #12) so that the dust does not accumulate inside the area where the blade spins or does not blow out the back hole. I have not seen any setups discussed on this forum with such a primitive "drop down into a tray" dust collection system. I am wondering if this is because this is a VERY BAD IDEA or just because all you forum guys just use your table saws inside where a vacuum setup is more essential.
Does anyone have any thoughts, advise, or experiences with this type of dust collection setup? For example, would removing the DUST COVER #12 expose the motor to too much dust causing the motor to fail early? Would saw dust blow profusely out the various passage ways making the tray useless to catch/hold the sawdust?
LCHIEN
