Installing laminate flooring & need to rip the first and last rows. At last an excuse to set up the BT3100 my wife bought me for Christmas '05
(still haven't used the scroll saw she bought me a few years before that. No free time with 4 kids. Maybe I'll use it to do some corner & doorway cutouts.). Anyway, set it up a two nights ago with no problems. Aligned it last night. I heard many are fine out of the box, but not this one. I adjusted the 90° blade angle. There's some blade/arbor runout, but I'll wait & see on that. I spent a lot of time getting my dial indicator fixture usable with the limited scrap I had around. Took the sideways slop out of the SMT. There's still a little on the front, but it was tough to get it w/o binding the sliding action. The SMT base was out of alignment, and that took some time, too. Did the 0° setting on the miter fence. Almost there. The rip fence shouldn't be too bad. The back side is closer to the blade & can't have that. Loosen the 2 screws on top & try to adjust. Can't get it, still closer in the back. Try messing with the two things under the front that rest in the front rail slot. No luck. I ended up taking it apart & widening the 2 holes with a dremel. That finally did the trick. Has anyone else had this problem? And, just to make sure it went back together properly, does the rod just sit in that round fixture inside at the back? Or does that small post through the rod need to fit in somewhere? Thanks in advance.
LCHIEN
