Freud saw blade and stabilizer
  • jrow
    • 19
    • Chesapeake, VA.
    I'm planning on buying a Freud LU87R010 10" x 24 tooth Flat Top Industrial Thin Kerf Rip Blade from Amazon. Should I also buy the Freud SC-001 3-1/2-Inch Blade Stabilizer with 5/8-Inch Arbor to use with it ? Is it necessary when using the thin kerf blade? Will it fit the BT3100? Thanks
    • 22063
    My recommendation is to forget the staibilzer.
    Comments in the BT3 FAQ to that effect.
    • jrow
      • 19
      • Chesapeake, VA.
      This question has been asked a few times before. Next time I'll search for the answer first.
      Thanks
        • 22063
        Thanks
        I wasn't trying to be abrupt.
        If you want details on why the stabilizers are not useful,
        send me a private message with your e-mail and I'll send the BT3 FAQ to you.
        It has come up from time to time and the same answers go out. You can look in the FAQ or do a search and sort thru the discussions to find the right one (http://www.bt3central.com/showthread...ght=stabilizer) or ask again.
        I gave you the answer, "no", if you want the details, they're in the FAQ.
        Mine sits at the bottom of a drawer, I wish I'd had a faq to refer to.
        • Knottscott
          • 3815
          • Rochester, NY.
          • 2008 Shop Fox W1677
          With a high quality thin kerf like the LU87 there should be no need for a stabilizer. The vast majority of those who've tried them don't see a difference. It'd benefit the seller more than you...save your money!
          • jrow
            • 19
            • Chesapeake, VA.
            You have answered my questions. Thanks for the help
              I attended a demo by a Freud rep. He said that the stabilizer was not needed. I ask why they sold them and his reply was that people buy them.
