BT rail extensions
  • reddog552
    • Dec 2006
    • 245
    • Belleville Il.
    • Bt3000
    BT rail extensions
    I had these made for me any comments. I am looking to produce these would like to get responces from this fourm.
    The bitterness of poor quality lingers long after the sweetness of low cost is forgotten!
    • 22098
    Looks good -
    At any given moment the demand is low and with the demise of the saw ultimately demand will be falling, but there is a slow demand.
    Depends on how much you will charge for a set (four pieces required), much over $20 I imagine will not sell well at all.
    Not the kind of thing I'd quit my day job for.
    • timb
      • Feb 2007
      • 76
      • Northern CA, USA
      Look nice but you have quite a lot of competition for this as a part for sale
      1. Stock parts are available
      2. Not too hard to make it yourself
      3. There is at least one other maker of something similar
      On the other hand Sears is not selling the rail extensions as standard accessory for the 218290 - the only way the saw is sold currently - so there could be a trickle of takers going forward if you can keep the price down.
      So not a money maker but if you want to make it available to others just because, that's great.
      Tim
      • Garasaki
        • Sep 2006
        • 550
        Those look nice.
        Like others have said, there is pretty much 0 chance you'll make money on these.
        However, if you are really cool and want to provide those of us here at the forums with those for really cheap, that'd be awesome! I'd be first in line
        -John
        -Henry Blake
        • os1kne
          • 901
          • Atlanta, GA
          It looks good, but it's tough to make much of a profit from making a relatively simple accessory for a table saw when your target market is people that tend to be fairly handly (unless producing the accessory requires a special skill that is a barrier for most people to try to do themselves- like the SharkGuard). T-nuts and angle are tough to compete with.
          I don't mean to be discouraging, but no matter how slick something is - there still needs to be several people willing to pay $ in order to make the deal worth doing.
          Good luck!
          • axa
            • Mar 2007
            • 98
            I machined the same kind of 'T-Bar' I call it, for my table.
            If you machine carefully, about 1.030 mill for the major, and 0.790 for the minor, you will find that you get vertical support from both the inner and outer lips, across the entire length of the bar.
            These other extraordinary priced kits available for sale, rely on support only from the combination of the arches of the 2 T-Nut inner circles, for each side of the rail.
            I run a solid 12" tool steel T bar, and found any more than that is overkill, because sag comes not from the rails, but from the load on the thin aluminum saw housing itself.
            I notice your bars are aluminum, easy to machine, but you might find your machinist can get various steels much cheaper, and steel is more rigid. But even a longer bar of aluminum will support better then the strongest shorter steel due to the distance between the pivot points.
            Anyway, I considered that I could make a decent profit selling a better product at less a cost of what is available. I already have material and tooling, but what I don't have is the time.
            I agree the demand is questionable, but yours kit is far better than what is available. Now whats your price...
            • reddog552
              • Dec 2006
              • 245
              • Belleville Il.
              • Bt3000
              Bt rail extentions
              Thanks for the Input Guys As for selling these didnt expect mutch. I had these made fore me [to cheap to buy a set] I still need to see what they would cost to make. I have axcess to a cnc mill,all the aluminum I could ever need,stainless hardware out the butt. As i said just checking if some of the fourm members might be interested in a set. These were made as a favor,they work realy well as they are pretty tight,requires a little gental tapping to get into place.Again thanks for the help Ill get the info on cost and get back to ya
              • Tom Miller
                • 2507
                • Twin Cities, MN
                Originally posted by reddog552
                I have axcess to a cnc mill,all the aluminum I could ever need,stainless hardware out the butt....
                Don't be a stranger....
                Regards,
                • steve-norrell
                  • 1001
                  • The Great Land - Alaska
                  Nice metal work. Should provide a considerable amount of rigidity to any joint. Questions:
                  How do you keep the T-bars in place?
                  Is there a piece that is used on the outside of the T-slots? Another bar? Large washer?
                  Do the bolts 'dig' into the inner surface of the T-slot on the rails?
                  Could the devices be machined with just enough clearance so that they could be used conveniently with the rail hinges available from T-Nuts.com? For example, if they could be slid into one side or the other, the rail could be folded down using the hinges.
                  Regards, Steve
                  • greencat
                    • 273
                    • Grand Haven Mi
                    • 3100
                    I would be interested if the price was right.
                    Thanks again,
                    • Garasaki
                      • Sep 2006
                      • 550
                      I'm definately interested too.
                      -John
                      -Henry Blake
                      • BT3 WOODOG
                        • 50
                        Yea,Me three!!!
                        • reddog552
                          • Dec 2006
                          • 245
                          • Belleville Il.
                          • Bt3000
                          Rail extentions
                          Yes the bolts [dig in] I am not to worried about this since I will not be disassembling it again this is a moot point. Here is the damage done. Excuse the poor quality pictures PC camera.
                          • axa
                            • Mar 2007
                            • 98
                            I imagine people are concerned with this purely for aesthetics reasons.
                            This is a much more simple system to keep the bar in place, rather than relying on 2 separate pieces squeezing together.
                            What I did on mine was to round off the ends of the bolts, so the threading doesn't leave that mark.
                            • steve-norrell
                              • 1001
                              Thanks for the feedback.
                              These devices would, indeed, make for a very strong, stable, permanent attachment.
                              A person who wanted some flexiblity could use a 1-inch piece of steel (on the outside of the rails) by drilling four appropriately located holes. The 't-bars' would have to be machined slightly undersized so that they slid along the t-slots.
                              I want to be able to fold down the rails on occasion and would be interested in the bars if they could slide through their slots.
                              Regards, Steve
