Hello to the board, this is my first post.
I have inherited my father's woodworking equipment which includes at BT3000. I was really happy to find this site and all the great information here. It will be a great help to me as I start to use the saw.
There were a few things wrong with my dad's saw when I got it. The knob had fallen off the height adjustment wheel - I found the info on the board here and ordered the Sears wheel. The switch is a little scary to try to turn off and I also found out about the recall on the board and Ryobi is sending me a replacement switch.
The last problem is one I couldn't find out here on the board so I thought I would share it. The far side of the fence wouldn't lock down and the front side barely locked. I took a good look at everything and couldn't figure out what was wrong. Finally I realized that my cam was completely worn. There was so much steel gone that I thought that this must be the way the part was made at first. Here's a picture of the worn part:
So I ordered a new cam and installed it and the fence locks down great. The saw is a 9311 serial number. They must have had a bad batch of cams that were really soft for it to wear like this.
Anyone else every had this problem?
Matt
Matt
LCHIEN
