Bt3100 router table "ring" inserts?
  • Matt_W
    • Feb 2007
    • 8
    Hi guys,
    I recently mounted my Bosch router under the table on my Bt3100. Problem is, the dust collector on top doesn't do a darned thing because all of the dust and chips fall under the table. I chose to make my own mounting plate for the router, and the hole around the bit is so big that everything falls below. Where can I get those red insert "rings" that you can put in the table to close up the space around the bit?
    I chose not to buy the accessory kits and make what I needed...but what other solution is there? Or is there some place I can just buy those rings?
    Thanks,
    Matt
    • 22106
    the part numbers are listed in the BT3 FAQ.
    you can get them from the spare parts suppliers for the BT3, also listed in the BT3 FAQ.
