BT3000 to 3100 Upgrade ???
  • movnup
    • Aug 2006
    • 190
    • Seattle
    I just saw a BT3100 on craigs list that he only wants $100. Beside the better shim design and black colored rails / different top top material it is worth the time to swap them out and part out / sell the first one ???
    I couldn't find the article that used to be on the forum for the differences .... Thanks!!!
    Parting out your BT3000 you should be able to make your money back and then some. I'd say if you have the money to spend, go for it. At worst you have 2 saws and one can be a dedicated dado saw or something.
    • Tanzer
      • Feb 2007
      • 12
      If you part out your BT3100 I'd be interested in the front & rear rails.
        Internet Fact Checker
        • 21010
        from the BT3 FAQ
        The BT3100 is like a BT3000 except for the following:
        splayed base
        improved vertical shim retention
        improved riving knife shim set (easy entry)
        different front panel,
        different paint scheme (blue and yellow instead of gray/black)
        gray metal-flake powder covered top instead of gray anodized top
        SMT base is black instead of clear (natural Aluminum) anodize
        black instead of silver rails. Slight but not significant profile shape, all known accessories
        still fit
        different shape on rip fence front rail clamp but same basic mechanism
        different elevation crank – plastic with yellow hub (and not the same as Sears, either)
        no instructional video tape (although lately some new owners have reported receiving
        DVDs)
        Notably it does share the nice 36T Freud thin kerf blade.
        BT3100-1 version which the main change appears to be a new power switch
        As of about December, 2005 the Freud Italian-made blade on new BT3100s seems to be replaced
        by a Chinese-made blade.
        Key components/spares/accessories available from Ryobi distributors and Sears are all
        interchangeable.
        If you want a copy of the BT3 fAQ, send me you e-mail addy by PM
        • Popeye
          • 1848
          • Woodbine, Ga
          • Grizzly 1023SL
          Go buy it Jim. Unless the motor is burned up it's worth more than that in spare parts and there are some things from your saw that will come in handy on the new one. I'm thinking of the accessory table first. Pat
            When I got my BT3100 I mounted it on the old BT3000 stand which I prefer. Then put the old 3000 on the 3100 stand and converted it into a permanent dado saw.
            • mrojec
              • Aug 2006
              • 63
              • Englewood, CO
              • Ryobi BT3000 (for now)
              I'd be interested in the motor from your BT3000 if you buy the 3100.
              Mark
