Router table
  • charger1966
    • 146
    • Amsterdam, New York
    • Shopsmith 10ER (1948),BT3100 New to me January 2007
    Router table
    OK Hello again, I was wondering what everyone else uses in their router Accessory Table for the insert to set up using a guide bushing? Looking at the plugs that come with the BT3100 accessory table, none allow the Guide Bushings to be installed.
    Please all info is useful info.
    Keep Making that Sawdust.
    Lance
    • 22104
    there's probably no real good way to get that done with the BT's auxiliary table.
    That's a good reason to build you own separate router table, the ability to use bushings in the table. That said, I guess I have yet to do it that way - I've used bushings hand held but not with the router mounted in a table although there are reasons why you'd want to do that.
      I've never used bushings in a table mounted router. I always use a split fence or a single pin in the table to guide a template on.
