Keeping BT3K debris from vac hose?
    I keep the normal throat plate on the BT3K because I often cut bevels. But when I have thin cut-offs that are short enough, they tend to fall into the saw and get sucked into the vac hose. If they are just the right size, they will clog it up somewhere along the line.
    I've thought of just getting some gutter screen and cutting a piece that will fit over the hose, but I think it may be a pain getting it to stay in place.
    Anyone else have a creative solution to this?
    Thanks,
    Phil
  • ChrisD
    • 881
    • CHICAGO, IL, USA.
    Yes, Phil: Get rid of the Cheerios!
    Chris
      • 4715
      IMHO if you are cutting small pieces you really should be using a ZCTP. If you do a lot of bevels it might be worthwhile to make some bevel ZCTPs.
      I think a screen would quickly become plugged plus the added danger of having to fish for your cutoff's. Not to mention that you might have to remove the TP to retrieve the cutoff anyway.
      You could reduce the number of ZCTP you would need by perhaps making each bevel one 5° wide by starting at 0° to 5°, 6° to 10°, etc. That would reduce the number of TPs you would need to perhaps 10 or 12 depending on dado etc.
        Internet Fact Checker
        • 21010
        how about this. If you are too lazy to change the throat plate, then lower the blade, put a piece of 2" wide masking tape across the entire length of the throat plate, then raise the spinning blade through the masking tape. (please turn off the saw while applying the masking tape!)
        Now cut normally. The tape will sag a bit, maybe rub against the blade. It won't provide any real support for splintering and such but will catch any slivers. It's soft and will tear so any hanging or catching will not result in a kickback, I think.
        This was just an off-the-cuff thought. I haven't tried it. If it seems at any point to be dangerous, stop, don't do it!
        OTOH, if you are too lazy to do something you know you should do, that's a bad sign...
          Speechless.
          • Lonnie in Orlando
            • 649
            • Orlando, FL, USA.
            I like to use clear packing tape to cover the opening. It's thinner than masking tape and the workpiece doesn't catch on it. Loring's suggestion to raise the blade though the tape sounds like a good idea, but I just put one edge against the blade.
            I keep the packing tape in the house, and masking tape in the garage/shop --- so I often use masking tape if I need to make a quick cut. They both do the job.
            - Lonnie
              • 21010
              - Lonnie
              Yes, that should work just as well or better, and its faster & easier (no monkeying around with the blade height). And, its actually been done.
