Advice re: mobile base for BT3100
  • Saminhillsboro
    • 9
    I recently bought a BT3100 and was thinking about putting in on a mobile base. Does anyone have any advice about that? I've seen the Herculift at HD and Sears has something. Making one seems not-unreasonable, but it's probably worth it to me just to buy it.
    Thanks,
    Sam
    • 22047
    Thanks,
    Sam
    I have three tools (BT3000, bandsaw, and jointer) on HTC2000 mobile bases. Catch them on sale at
    Amazon for $40-something. They are also available at Woodcraft and sometimes Sears with store labelling.
      I chose to build my mobile bases using this Wood Magazine design:
      http://mysite.verizon.net/imagelib/s...g&target=_self
      It was not cheaper than the HTC or Rockler bases, but it offered some satisfaction in building a nice project.
      • Warren
        • 441
        • Anchorage, Ak
        The BT is the ONE tool that I do not have on a mobile base. I found a place for it and basically centered the shop around it. I did set up the casters on the base and can move it when absolutely required. I did this simply because it's one tool that can be complicated to "dial in" and I wanted it undisturbed as much as possible as I have a long table on it and an outfeed table.
        Some of the mobile bases, with storage, that a few of members have designed, certainly remove that consideration as the saw is not really disturbed when the unit is moved around. I'm the one that's seriously disturbed. I'm thinking of making a cabinet style base as my summer project.
        • Saminhillsboro
          • 9
          Thanks Loring, JR and Warren.
          • eezlock
            • 997
            • Charlotte,N.C.
            mobile base
            Might want to check this one out from Sears ....the 22303 universal mobile base. I bought one shortly after buying the Bt3100 saw. You have to stretch it all the way out( maximum opening on all sides) and it will work. I had to tap the legs in lightly with a rubber mallet till it dropped all way down into corners.
            A nice tight fit...it works good for me! eezlock
            • Greg in Maryland
              • 250
              What issue of Wood Magazine? This looks like something I would like to try to undertake.
              Thanks.
              Greg
