I have a BT3000 that is about 12 years old. Although I have never been impressed with the smoothness with which the bolt for the miter fence adjusting clamp slides inside the slot of the miter table, it has always worked.
However, a few days ago, I was unable to tighten the adjusting clamp in the zero dgree position. When I checked out the underside of the slot in the miter table, I noticed that the steel bolt has worn a pocket in the edges of the slot, something that I've had a suspicion might happen one day. It doesn't surprise me, considering the relative difference in hardnesses between the steel bolt and the aluminum table.
I certainly cannot be the first one to encounter this issue and I'm wondering if anyone has come up with a solution other than replacing the miter table itself. Thanks for any input.
JMW
JMW
