I just bought my 21829 and had the same question, I think Ill give the 3.5 inch idea a try. Kiredude can you post what you have done or found out about this? Thanks
Question on rip scale
Fix for Scale Sticker
I'm glad to hear that my 21829 saw is not the only one with the scale sticker adjusted to the far left.
I contacted Sears' 800 number about it and they are sending me a replacement Scale Sticker free of charge. It should be here within 5-7 days. I will remove the old and either place the new sticker in the middle or right justify it since I don't plan on having the fence left of the blade too often.
If you are unhappy with your sticker, give Sears a call and have them send you a new sticker under warranty.Comment
The scale on the rail....
I've never used the scale on any saw that I've owned. I always set the fence up by measuring directly to the blade. This, I think, eliminates any problem with the difference between the center of the scale and the actual blade.
At least it's worked for me for many years.
Cheers,
MikeRComment
I don't remember where I got mine but Lee Valley is a good source. Hartville tool is another. They cost $5-10. I use a scale I stuck on for crude measurement but I use a metal rule for more precision measurements. There is enough distance between the pointer and the scale using the rip fence pointer and scale that you can get off 1/64 or even a little more depending on your exact position relative to the saw. I find that a ruler solves this for me. It's still handy to get close with the scale. I shift my rails around so I also do not find it convenient to keep zeroing them after shifting - easier for me to just consider them a rough guide.
JimComment
I just looked at the picture of the saw on the sears website. It looks like you have about 4 inches of movement for the SMT if you set the scale to 0. Does that sound about right?
If that's the case then I think the scale for the BT3 are similar. I know I have mine set to 0 and I don't have alot of area for movement on that side. But in all honesty, I don't move the SMT that much. I've never found a big need to put it further from the saw.
Now if you are planning on using the rip fence to the left of the blade as your norm, then I can definitly see why you would want more rail length over there.Mike
Lakota's Dad
If at first you don't succeed, deny you were trying in the first place.Comment
