The motor housing will not raise or lower. It appears that threaded hole in the motor housing fig 43 on page 33 has stripped. The elevating shaft just spins and doesn’t move the motor housing up or down when I turn the blade adjusting handle. Page 48 of the manual shows item 9 as the motor bracket assembly. I’ve found the part # 4800031 for this item, but can’t seem to find where to but it... can someone give me a link for a parts supplier.
Also has anyone experienced this problem? It looks like major surgery to replace this part. What am I looking at as far as replacement of the part.
Terrible timing with the holidays so close and I’m behind on my gift making.
Any help would be appreciated
Thank you very much
Thank you very much
LCHIEN
