dado set
  • davwho
    • 16
    • Petawawa Ontario
    dado set
    well its that time of year coming,and the wife is asking me what i want,of the many,many things i want ,i would like a dado set ,can someone please tell me what works best with the BT3100 within a reasonable price,ive heard the freud SD206 is a good choice,please shed some light
    Thanks
    Dave!!
  • LYU370
    • Mar 2005
    • 215
    • Streamwood, IL.
    I've got the SD206, works quite well, although the price seems pretty high right now. Also heard that the Avenger dado sets are pretty good as well. Stick with a 6" set instead of the 8" sets, clearance issues if I recall correctly.
    Andy
      • 22106
      Avenger is out of production - company closed doors. CAn't get anymore except on occassional rare clearance sales. Besides, it's plates and chippers never quite stacked up the way a dado's ought to.
      The link below my sig line to the FAQ will work for a few more days.
      It has answers about dados.
        I have the SD208 8" set and it works fine. Had I known better I'd have gotten the 206. I can't see ever needing the extra dado capacity the 8" gives me. 206 does not have the potential clearance issue and is less mass for the motor to spin so it doesn't have t work as hard.
        • scorrpio
          • 1566
          • Wayne, NJ, USA.
          I have SD206. Excellent set, very clean cuts.
          • davwho
            • 16
            • Petawawa Ontario
            re. Dado set
            Thanks guys ,the Freud SD206 it is
            • gimpy
              • Nov 2004
              • 197
              • Flagstaff, AZ.
              Loring, not to be too nosy, but, just curious. You said that link would last a "few" more days. You aren't leaving us or anything are you? Hope not.
              Hope it is just something to do with your sig or something.
              Thx, Frank
              Frank, "Still the one"
                • 22106
                Thx, Frank
                Oh, My ISP is calling it quits so I'm losing my Web space on Dec 4.
                I guess I need to get on the ball and find a new ISP. I can change the link in my sig and on BT3 Central, to the FAQ, so it'll be OK, but there's too many other pictures I've posted here to change them all.
                • Cheeky
                  • 862
                  • westchester cty, new york
                  • Ridgid TS2400LS
                  does anybody have the Dadonator?
                  http://www.infinitytools.com/products.asp?dept=1167
                  Pete
                  • Knottscott
                    • 3815
                    • Rochester, NY.
                    • 2008 Shop Fox W1677
                    Originally posted by Cheeky
                    I don't own it, but have read positive comments from owners. But if I were looking that price range, I'd definitely consider the US made Ridge Carbide set over the Asian made Dadonator. Holbren's got it for $190 shipped, and it'll have the fattest top shelf carbide you've ever seen!
                    http://holbren.com/product.php?produ...1&cat=0&page=1
                      I was able to pick up that dado locally for $20 via a damaged freight store a few years back. Bought it for the radial arm saw. HOWEVER I have only seen it in 8", which you linked to. For the table saw, I would stick with a 6".
                      If there is a 6", would Holbren chime in?
                      • footprintsinconc
                        • 1759
                        • Roseville (Sacramento), CA
                        dado blade - delta 6"
                        i am looking at this dado set by delta, its for 30.00 only at rockler this thanksgiving friday sale only, will it fit into a bt3100?
                        http://www.rockler.com/product.cfm?p...TOKEN=21169593
                        thanks
                        omar
                          • 22106
                          thanks
                          The biggest thing to watch for, is the max rated RPM, if you have a BT3 saw. The BT3x turns at 5000 RPM max, most saws use 3600 RPM. Check the fine print on the saw body itself (could not read it in the enlarged picture link), you want to make sure it is good for 5000 RPM, minimum. Dodging little bits of flying carbide are not fun.
                          Other than that, this dado should fuctionally work fine. The smoothness of cut, the bottom soothness and the stackup tolerances of the plates and chippers I can't guess at.
                          • steve-norrell
                            • 1001
                            • The Great Land - Alaska
                            thanks
                            According to the "Details" page at the Rockler link, the blade is rated at 6000 rpm. Should be great in the BT3100.
                            • onedash
                              • Mar 2005
                              • 1013
                              • Craftsman 22124
                              My buddy has a webhosting company http://www.kalypsoweb.com/ and his prices are pretty cheap.
                              Its the first one I have ever had that I paid for and am happy with it.
                              I am trying to do CSS but that is kinda kickin my butt since I am using trial and error. I haven't messed with it a whole lot since I moved but still have the one running at the free place too.
