Upgrading shims to BT 3100 parts
  • jabe
    • 577
    • Hilo, Hawaii
    Help, my BT 3000 shims needs to be replaced. I understand that it can be upgraded with the newer BT 3100 parts. What I need to know are what parts do I need, parts descripitons, part numbers and where I can order them. Also, any instructions or advice on how to make this change.
    Thanks
    Jimmy
    Here are the parts to get from Ordertree:
    SKU Name
    0181010314 SPRING SHIM
    0181010110 GUIDE HOLDER BT3100
    Here's my thriead on this topic. http://www.bt3central.com/showthread...highlight=shim
    Here's BlackWallnut's excellent thread on topic: http://www.bt3central.com/showthread...ighlight=shims
    It's pretty easy to do and a good opportunity to tune up the innards of your BT3K.
    Good Luck,
    • jabe
      • 577
      • Hilo, Hawaii
      Thanks JR. I recall seeing your post earlier this year. Did you complete your upgrade?
        • 22031
        if you want to double check the list of conversion stuff is also in the bt3 faq, Link, under my sig line below, search for SHIM.
