Trying to find elevation/tilt crank article
  • TJG
    • 57
    I know I saw it about 9-12 months back, but I can't seem to find it now. It was on this site, and it was either a forum message or article about modifying the elevation/tilt crank handle. I seem to recall the author used lead shot and epoxy to reinforce the crank handle. I appreciate any help in locating the article or message.
  • gmack5
    • 1972
    • Quapaw, Oklahoma, USA.
    • Ryobi BT3000SX & BT3100
    Wrong Site!
    I believe it was by Jim Frye on the Ryobi Woodworking site, I could be wrong, but I don't think so.
    Go to their site, sign in and do a search, you should be able to find it.
    George
    • TJG
      • 57
      Thanks. That is what I was looking for. I'm not sure if it is the exact same item (seems like the other one had pictures included) but this tells me everything I need to know and the pictures weren't necessary.
        • 22039
        Originally posted by gmack5
        I believe it was by Jim Frey on the Ryobi Woodworking site, I could be wrong, but I don't think so.
        I think that's right.
        • Kristofor
          • 1331
          • Twin Cities, MN
          • Jet JTAS10 Cabinet Saw
          I distinctly remember seeing that, but I don't use the Ryobi forums. So, I know it was at least linked from this site (can't imagine it would have been on sawmill creek or woodnet the other two I look at occasionally). However, I can't seem to shake it out of the search engine here, but that's a different subject...
          You are correct that the person used both epoyx and lead, but he also mentioned a gotcha of some sort about drilling holes or the order of opperations that would probably be useful to read again before doing it yourself.
          Sorry, not much help.
          Kristofor.
            • 22039
            Here's the post. took me five search attempsts to find it.
            Finally just got a list of all posts by Jim Frye (40)
            http://www.bt3central.com/showthread.php?t=16750
            • TJG
              • 57
              That's the one I remember. Of course, the other post was also fine, but this gave me details regarding a few pitfalls to avoid. Thanks again for everyone's assistance.
