BT access kit
  • ducter
    • Jul 2006
    • 6
    BT access kit
    I found a HD that has 2 bt3100 available at 239. They dont have the access kit. Should I still buy the saw(need a TS) , what is in the kit that I cant live without? I do want casters but I can do those myself. Thanks
  • bigsteel15
    • 1079
    • Edmonton, AB
    Buy the saw. Don't worry about the kit.
    The only thing of any real use is miter slot but you can make that pretty easy when you get the saw and research around here.
    Brian
    Welcome to the school of life
    • Ken Weaver
      • 2417
      • Clemson, SC, USA
      • Rigid TS3650
      What steel said - nothing in there worth waiting for or that you couldn't make for yourself.
      Ken Weaver
      Clemson, SC
        • 22056
        for comments on the accessory kit, check out the BT3 FAQ.
        There's a permanent link in the first post under "Getting Started" forum here on BT3 Central.
        • ducter
          • Jul 2006
          • 6
          Got It!
          Went out and got it! Paid 239.00 they actually have 4 shrink wrapped in addition to the display when I was there. This was in Garner, NC.
          • gmack5
            • 1972
            • Quapaw, Oklahoma, USA.
            • Ryobi BT3000SX & BT3100
            Welcome to the Family
            Welcome ducter,
            Congratulations on the acquisition of your BT3100 and welcome to the "family".
            One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the preceeding proceedure, so you MUST keep them in sequence.
            A good one will cost you quite a bit of money, $40 - $75, or more.
            I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square.
            The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
            When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
            Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate.
            Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes.
            The reason is simple, most of them contain Silicones and they will make your projects difficult, if not impossible, to finish.
            entire saw.
            Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
            You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/
            The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site).
            One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
            This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea.
            One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
            It's a line that extends the line-of-sight from the saw blade to the front edge of the table to remind you NOT to let your Miter Fence or your FINGERS get in the way of the saw blade. Just put red paint, nail polish, or what ever, in the groove that extends towards the operator from the front edge of the saw blade.
            George
            • Ken Weaver
              • 2417
              • Clemson, SC, USA
              • Rigid TS3650
              Good on ya Ducter. Set er up and let er rip (so to speak)! Have fun, make sawdust and be safe!
              Ken Weaver
              Clemson, SC
