Want an excellent blade for .75" MDF and 1/8"-1/4" ply
  • jonathanb3478
    • May 2006
    • 21
    • Sacramento, CA
    So the first canidate is the TENRYU ML-25580AB (got this recommendation from them by email).
    It is the second one down at this link:
    http://www.mytoolstore.com/tenryu/melpro.html
    That seems to be about the going rate for this blade. So, I am looking for opinions on this blade for my use, and specific alternate suggestions. I will be keeping the stock blade in case I need to do things like pine 2X4s, etc.
    I do not want to spend more than I need to, in order to get high quality edges on the material I am cutting. I will be spending what is needed to accomplish this, however.
    Thanks!
    • 21985
    That one is designed for specifically cutting laminate like with a thin melamine top.
    I'd personally go with a Forrest Woodworker II 40T that will run you $89-95 at Amazon, Woodcraft or Rocker. Avaialable in 1/8" standard or 3/32" thin kerf versions, your preference.
    Gives a great cut in MDF and most all woods and plywood. All-purpose super who-ha blade.
    It's easily the most popular "high-end" blade around here.
    And yes, I have one.
    • jonathanb3478
      • May 2006
      • 21
      • Sacramento, CA
      The Forrest blade I am interested in (checked them out on Amazon) is the Woodworker I 10" x 60-Tooth, Thin Kerf Blade. It is a little bit more expensive, but seems better suited for what I will be cutting (exclusively). Any thoughts on this one vs the Tenryu?
      • vaking
        • 1428
        • Montclair, NJ, USA.
        • Ryobi BT3100-1
        That's a lot of money to my taste - as you can see I am cheap. MDF is a nasty stuff that quickly ruins any blade. If I were in this position I would have bought something like this for MDF exclusive:
        http://www.amazon.com/gp/product/B00...lance&n=228013
        It probably is not as good as your first choice but you can get 3 blades for same money. The blade for thin plywood is a different story. Now you are talking delicate and probably expensive ply. That might justify WWI or equivalent.
        Alex V
        • RodKirby
          • 3136
          • Mao Shan TSC-10RAS
          Ditto from me
          Downunder ... 1" = 25.4mm
          • jabe
            • 577
            • Hilo, Hawaii
            Aloha,
            I do a lot of cabinet work with Okumi lumber core plywd. with laminate/melamine on both surface. I use Tenryu blades with great success. I use the Mel-Pro 10" x 100 tooth or their Alumi-cut 10" x 100 tooth blades. The Alumi-cut 100 T blade is cheaper than the Mel-Pro and it does a good job on the Okumi plywd. Do not buy the 80 T Mel-pro or Alumi-Cut, it does not do a good job on this type of material. Melamine/laminates are hard on any brand blade, just have them sharpened regularly. I have 3 of each blade as backup so when 1 is being sharpen, I still do not have any down time.
            I use Tenryu Alumi-cut 7 1/4" x 60 T on my circular saw and panel saw, just to rough cut the sheets, then do all the finish cuts on my table saw. I bought 2 Forrest 7 1/4" Duraline HI-AT blades $ 129.00 each, to use on my circular saw & panel saw, boy was that a mistake, it just chipped the **** out of the melamine.
            • Tom Slick
              • 2913
              • Paso Robles, Calif, USA.
              • sears BT3 clone
              IF you are looking for the "best" blade for plywood/veneers/melamine then you need the forrest duraline hi/at
              http://www.forrestblades.com/hiat.htm
              it doesn't splinter or chip what you are cutting.
              • jonathanb3478
                • May 2006
                • 21
                • Sacramento, CA
                I think I might give that blade a shot, before trying the more expensive solutions. I would at least have a blade to use when any expensive blade I end up with needs to go out for sharpening.
                • gimpy
                  • Nov 2004
                  • 197
                  • Flagstaff, AZ.
                  Be sure and use a zero clearance insert for the ply and put the good face down when cutting on the table saw. This will help with splintering. There are also a couple of other good tips floating around.
                  Frank.
                  Frank, "Still the one"
                  • Knottscott
                    • 3815
                    • Rochester, NY.
                    • 2008 Shop Fox W1677
                    I love my WWII...it does a great job in alot of applications including plywood, but a good Hi-ATB grind would do better. The Freud LU80R010 is one such blade at a reasonable price. The Forrest Duraline is another, but it's big bucks.
