Power switch on display model
  • bigsteel15
    • 1079
    • Edmonton, AB
    I was in a local HD yesterday.
    While looking to see the condition of the display model BT3, I notice that it has a different on/off switch than my 1 yr old machine.
    The one I have is the usual red plastic toggle..lift to on/push to off.
    This one has a hard plastic black cover with a black rocker switch underneath it. The lock-out mechanism is a wire that slips through this cover near the bottom. You lift the cover and turn on the switch, then push against the cover to turn off.
    Kind of a strange set-up but the switch appears to be of better quality than the one we all complain about. It also appears that one could replace it easier with a standard quality rocker switch if it ever failed.
    Is this an older machine on display or a newer one?
    Brian
    Welcome to the school of life
  • gsmittle
    • 2793
    • St. Louis, MO, USA.
    My BT is about two years old and has this switch. I always thought the red toggle was an "upgrade."
    g.
    Smit
    "Be excellent to each other."
    Bill & Ted
    • meika123
      • 887
      • Advance, NC, USA.
      Sounds like the switch on my early (2001 or 02) BT3000. I really like it this way.
      Dave in NC
      • mschrank
        • Oct 2004
        • 1130
        • Hood River, OR, USA.
        Sounds like they have an older model on display there...my BT is about 4 yrs old and has the rocker switch you describe.
        That saw probably also has the good old Freud blade on it as well.
          yeah, that's the older switch
          • just4funsies
            • 843
            • Florida.
            Yeah, that's the older one, allright. I know they had trouble with them, but mine has always worked, and I like it. I just punch it or knee it from practically any angle, and it shuts off. I'll miss it if it ever goes.
            • meika123
              • 887
              • Advance, NC, USA.
              Me too!!
              Dave in NC
