Where to buy Shims?
  • hobkirk
    • Jul 2005
    • 85
    • Acton, MA, home of the original Minuteman - about 20 miles West of Boston
    Where to buy Shims?
    Where can I buy BT3100 shims for my BT3000's?
    Thanks...
    Doug Hobkirk
    WOOD LOON
    • 22098
    have you looked in the BT3 FAQ?
    • Papa
      • 150
      • Williamsburg, VA
      Doug,
      I got my shims from ORDERTREE.COM. I converted to the newer BT3100 spring shims, so I needed a replacement guide holder also. The part numbers I ordered were:
      Part # 0181010110 - Guide holder BT3100 - 1each
      Part # 0181010314 - Spring Shim - 2each
      Part # 969600001 - Flat Shim - 2each
      See Black Walnut's instructions on the process in my thread of yesterday.
      Good Luck.
      Warren Bell
      PAPA, formerly LEADBELL
      • hobkirk
        • Jul 2005
        • 85
        Yes, I did...
        ...no hit in FAQ on "buy shims BT3000 BT3100"
        ...or "buy shims BT3000"
        ...or "buy shims"
        ...or "shims"
        At which point I asked my question in the forum.
        (I am quite sure I remember reading the answer somewhere)
        Papa -
        Thanks
        Doug Hobkirk
        WOOD LOON
          • 22098
          Originally posted by hobkirk
          Yes, I did...
          ...or "buy shims"
          ...or "shims"
          Papa -
          Thanks
          I clicked on the BT3 FAQ search "binocular" icon. First hit was a note about BT3100 not having shim problem. Second hit (Find next) was the following:
          Occasionally you will have the dreaded
          shim problem (a BT3000/Sears 22811 quirk, this has
          been fixed in BT3100s). The shims are thin metal plates that ride between the motor holder and
          the saw frame when traveling vertically. They are normally held in place with the motor housing
          but can be deformed and fall out when the lubrication is not adequate. If you find some small
          metal plate below your saw body then the shim(s) have likely fallen out and will need to be
          replaced as they are the anti-wear mechanism. Vertical movement will become difficult. The
          shims are inexpensive but the labor can be a few hours. Keep your saw lubricated in this area
          with a dry lubricant. A February, 2005 survey on BT3Central indicated that 70% of BT3 owners
          never had the problem but that 30% had some problem with shims.
          The BT3100 does not have the shim problem because the shims, though used, have a mechanical
          retainer. You can convert the BT3000 to the BT3100 shim system. The conversion is simple if
          you will have the saw apart to replace the belts and the cost is negligible
          Parts List:
          #969600001 Flat shim [BT3000/BT3100}$.90 ea, 2 needed
          #0181010314 Spring shim {BT3100} $.86 ea, 2 needed
          #0181010110 Guide holder {BT3100} $15.07 ea, 1 needed
          #662329001 Dvive belt {BT3000/BT3100} $13.49 ea, 2 needed
          The parts are available from:
          www.ordertree.com
          www.billious.com
          • hobkirk
            • Jul 2005
            • 85
            Loren -
            Holy Batman!
            That's exactly what I wanted!
            BUT...
            I don't have a clue what you're talking about [sorry]...
            • What "binocular" icon? [I even searched the Control Panel to see if there was a "graphic" option I hadn't activated]
            • Did you enter any word(s) and do "search"? Or did the "binocular" produce other options?
            Maybe I should change my signature to "Clueless"
            Doug Hobkirk
            WOOD LOON
              • 22098
              Loren -
              Holy Batman!
              BUT...
              Well, its confusing because there are several FAQs. Follow these directions exactly.
              Don't go to the Forum FAQs, they just tell you how to use the forum software.
              Do do this: navigate back to the forum Discussions
              select the forum discussion "Getting Started"
              In the first thread, its entitled something like "StickY: Official BT3Central FAQ & Acronyms"
              Click that one. The first post contains the links. Click on them.
              You will see Adobe Acrobat reader open if you have it, if not then you need to get this reader which most people have. The reader will display the FAQ and acronyms.
              The easy way is to just scan the brief list of questions at the start of the document and click on the one nearest yours. There's one something about what is the shim problem and what do it do if I get it? Click on the question, it's hyperlinked to take you straight to the answer.
              The other way is to use the Adobe Acrobat word Search function; click on the "Search" binoculars icon at the top of the reader.
              This is a word search like in MS Word, not a document search like Google. Enter a single keyword like shim and it will find the first instance of "shim" in the FAQ. Skim the surrounding text to see if this answers your question. There's another icon, binocular with a circular arrow, this is "find next". Keep using it until you locate an applicable paragraph.
