Hey guys, over the weekend I made an attempt to get my SMT in alignment.
My first step was to take any slope out of the table buy adjusting the cams and tabs. That went well and my table now has no slop in it.
My next step was to adjust base parallisim. By using a piece of wood with a screw in the end I was able to adjust the table to parallel.
My next step I feel is where my mistake is. I then adjusted the miter fence to 90 to the blade.
When I made my test cut I noted that I was well out of alignment. I think that since I adjusted the base with the wood jig on the SMT fence, and then adjusted the angle of it to 90, I screwed things up. Just not sure.
I want to take another stab at making the adjustments again. But to me it seems like if you adjust 1, it throws the other adjustment out of wack. Any ideas of where I'm going wrong.
LCHIEN
