I have a pretty basic BT3100 setup, but it does have the addition of a Shark Guard.
I also have a Jet DC-650K dust collector (650CFM, 4" connection).
I mostly use a ZCTP with the saw.
My dust collection plumbing right now is very simple. A 2.5" to 4" reducer is plugged directly into the saw's dust port. This is connected with 1' of tubing to a 4" Y, which is then connected with 5' of tubing to the dust collector. On the other end of the Y is a 4" to 2.5" reducer with 10' of tubing going up to a coat hanger hanging from the ceiling and then back down to the Shark Guard.
I think my Shark Guard is a 3.0 model (it is a bit over a year old). The dust port is about 2" and came with a shim to make it work with 2.5" tubing.
Dust collection is good, but not great. A fair amount of dust is usually flung out of the front of the Shark Guard onto the front of the saw. When I'm making dado's (I do this with the regular blade and just make many nibbles) dust collection is awful.
I think that my Dust collector is somewhat starved for air. When I run it without the Y (so there just 4" tubing) the dust in the collection bag makes a nice swirl. When hooked up to the saw as described above there appears to be a lot less air movement inside the collection bag.
What can I do to maximize my dust collection with the SG? Is there a way to add a larger port to it to get additional air flow. I've noticed that some users are drilling a hole into the front of the ZTCP which looks like it could help a lot with making dados. Where is this hole located?
I'd be interested in seeing how other people plumb their dust collection from the SG and combine this with the dust port on the saw. My solution (a coat hanger) is probably not ideal and might result in a sharper than ideal bend in the 2.5" hose.
alex
alex
