RoboReel $99 at Lowes
  • jussi
    • 2162
    I first saw the roboreel on of Marc's (the woodwhisperer) videos and thought I had to have one. Until I saw the $300 price tag. It's a basically a high end retractable extension cord. But it has alot of cool features like automatic rewind which automatically slows down during last few feet, automatic shut off if the cord is cut, thermostat for over heating, built in circuit breaker, and uses 12 gauge wire. Promo vid below.
    https://www.youtube.com/watch?v=43zQHnQCNBg
    Anyways I found these at Lowes for $99. The retail price has gone down a bit since I first saw them. I think closer to $250 now. They make a portable and ceiling mounted version. They also make a air hose in both versions. I got a little carried away and got the portable and ceiling mounted electrical cord and the ceiling mounted air reel. These are close out prices so YMMV.
  • woodturner
    • Jun 2008
    • 2049
    • Western Pennsylvania
    This may have been a trial in your area - it appears the items were never even stocked in this area.
    What is the item number for the electric reel?
    Thanks.
    • jussi
      • 2162
      Power ceiling 648042
      Power portable 648041
      Air ceiling 648040
      • gerti
        • 2233
        • Minnetonka, MN, USA.
        • BT3100 "Frankensaw"
        Looks cool! I bought a Flexilla air hose reel a while ago, and with that one the issue is that the hose does tend to bunch up on one side if the reel and then it will not retract all the way. Pretty annoying. Does this one reliably work as advertised? Does the rubber hose lay flat as promised? Would it do that also in the dead of a very cold winter?
        • jussi
          • 2162
          Yes from the very small amount of time I've been using it. Which is one day And it was mostly just taking to different parts of the shop and letting it retract. With the ceiling mounts you still have to guide it somewhat because there is a good chance it will get snagged on a piece of equipment or cabinets if you pull it far enough. But the automatic stop feature is really helpful in those situations. The portable model will get used outside the shop in a more open environment so I don't see that being as big a problem. I will probably use that model on concrete areas and I already noticed the plug section getting all scratched up. Kind of wish they made a sacrificial piece that could be replaced. I'll probably just put electrical tape around the areas that will tend to drag.
          Again, from the small amount of time I've used it, yes. The hose and electrical cord stayed flat.
          No idea. I'm in Southern California. Our version of winter is anything below 60
          • tfischer
            • 2349
            Seems awfully overengineered. I don't see how you'd ever cut an extension cord in the shop unless you were really being careless... in decades of use the only time I've ever nicked one was with the electric hedge trimmer, and I now use a battery powered one lol.
            As for the temperature sensor, circuit breaker, etc: don't overload your cords and you don't need that either. It's not that difficult... don't have multiple things running off the same cord at the same time. I often use a three-way splitter off of one 12g cord, but I'm only using one power tool at a time so that's completely safe.
            • jussi
              • 2162
              It didn't happen in the shop but I accidentally cut an extension cord when using a circ saw outside and carelessly put the saw down too close to the cord. It didn't completely sever the cord cut did nick one of the wires.
              The extension cords are def a luxury and are from a necessity. The automatic rewind is very cool and 100 times better than my old system, which never would fully retract. Plus it's 15 feet longer so I can reach the other side of my yard from the shop. And, so far at least, no binding.
              The circuit breaker while not completely necessary is nice for me because I sometimes wheel out my portable dewalt planer to use outside when the boards are too long. The thicker gauge wire and circuit breaker will allow me to use both the planer and a shop vac.
              • rcplaneguy
                • Nov 2012
                • 37
                They are $99 here at Lowes, too.
                Bought the wall mount air hose, ceiling mount electric cord, and portable electric cord.
                Thanks for the tip!
                • tfischer
                  • 2349
                  Yeah just to clarify my earlier comment, I don't think it's a terrible deal at $99. I can't imagine paying $300 for this though.
                  • jussi
                    • 2162
                    Did the wall mount come with the roboreel or did you have to buy it separately? I only saw the ceiling and portable versions. I like the idea of storing the portable version on the wall.
                    Thanks for the tip!
