Husky Pneumatic drill driver kit $20 +tax @ HD
    • 21993
    In addition, these tools are typically not used continuously, so even a $50 pancake compressor would be fine, provided you allow for recharge time between uses of a few minutes at a time.
    If one is going to use air tools, though, I think it's better to pay the $200 for the Husky 20 gallon which will run just about everything other than some spray guns (which typically require high volume, in the range of 8 cfm).
    yeah my pancake compressor seems to run them fine. Drills and drivers you tend to run in short bursts so the tank will take care of them. If you use a grinder or sprayer where the run time is a lot longer approaching 100% duty cycle then you will have problems.
    • tommyt654
      • Nov 2008
      • 2334
      It was listed online earlier but now showing OOS, If you want to get a price adjustment its $10 online now for those who paid $15 ir $20 before
      • annunaki
        • Jan 2008
        • 610
        • White Springs, Florida
        • 21829, BT3100, 2-BT3000(15amp)
        Can't find it. Can you post a link? SKU doesn't work
        http://en.wikipedia.org/wiki/Fileodecahedron.gif
        • tommyt654
          • Nov 2008
          • 2334
          Here ya go,hope it helps,but its no longer on HD website ,maybe a printout will get you the diff, this one shows it down to $8
          • jdon
            • Feb 2010
            • 401
            • Snoqualmie, Wash.
            Picked one up at W. Seattle HD for $8 this afternoon.
            • Ultraman
              • 33
              • Raleigh, NC, USA.
              $20 and back to HD
              Took mine back to HD along with the receipt and tommyt's printout. No problemo. Refunded the difference. Total final cost: $8.54.
              • Stytooner
                Roll Tide RIP Lee
                • 4301
                • Robertsdale, AL, USA.
                No experience with those. I did use a HF model drill that was about $15.00 several years ago.
                It was okay if used on the bench with the same drill bit chucked all the time.
                Swapping them out was not fast.
                The impact should be very useful though.
                I hadn't noticed those in air tools before.
                Air impacts, use them all the time, air impact drivers, nuevo!
                I don't think anyone can argue about price at this point.
                  • 10481
                  Picked a set up at the Kyle, TX HD today. $8.00 - 10% military discount + tax = $7.80 out the door!
                  3 more on the shelf when I left.
                  • tommyt654
                    • Nov 2008
                    • 2334
                    #24
                    Called my store today and got the P/A over the phone on the drills as well as the compressors I had purchased for a total savings of $70, enough for a tank of gas and a hekuva a lot easier on the phone than driving to the store
