Rare earth magnets - 100 for $18.40
  • Cochese
    • Jun 2010
    • 1988
    Just got an email from Peachtree on this. What great timing for my tool cabinet build.
    http://www.ptreeusa.com/edirect_072412.htm
    Remember to keep them out of reach of kids and pets.
  • BadeMillsap
    • 868
    • Bulverde, Texas, USA.
    • Grizzly G1023SL
    Good price thanks for the pointer!
    Bade Millsap
    Bulverde, Texas
    => Bade's Personal Web Log
    => Bade's Lutherie Web Log
    • annunaki
      • Jan 2008
      • 610
      • White Springs, Florida
      • 21829, BT3100, 2-BT3000(15amp)
      Thanks
      Ordered two sets
      http://en.wikipedia.org/wiki/Fileodecahedron.gif
        That is a good deal.... what was shipping for you on that?
        • greenacres2
          • Dec 2011
          • 633
          • La Porte, IN
          Peachtree shipping is $6.99 on purchase of up to $25, and $8.99 from $25 to $50. At least that is what i recall from yesterday--should be close!!
          earl
          • big tim
            • 546
            • Scarborough, Toronto,Canada
            • SawStop PCS
            Be sure to keep them away from little kids, they might swallow them.
            Tim
            • annunaki
              • Jan 2008
              • 610
              Got my two sets today Ordered on 7/24, shipped USPS 7/26, got on 7/28.
              • woodinville guy
                • 188
                • Cedar Park, TX
                I got mine. Ok so what is the best way to install them? drill the correct diameter hole and glue them in place?
                - Dave
                  You could do that. I would use quick setting epoxy personally. Peachtree also sells a cup that has a small countersink where a screw would hold it in the hole you drill. Take a look at the page, below where the magnets are listed. You should only need one magnet on an average size door, the other end could be a countersunk screw or small washer, etc.
                    • 22034
                    i have some neodymium magnets and I was unable to get them glued satisfactorily with hot melt glue. I set them maybe 1/16 or 1/32 below the surface of the wood, countersunk, and glued them in with hot melt glue. After cooling off I tried my wood faces on my vices and the magnets pulled right out of the glue.
                    Later I used some E6000 adhesive applied to sandpaper-scuffer magnets and it has seemed to hold. Relevant discussions:
                    http://www.bt3central.com/showthread...gluing+magnets
                    http://www.bt3central.com/showthread...glue+face+vise
                    • jdon
                      • Feb 2010
                      • 401
                      • Snoqualmie, Wash.
                      I don't want to hijack the thread, but a good (free) source of rare earth magnets is from worn out Sonicare toothbrush heads. With a rectangular shape, in some cases they might be preferable to round magnets. They're fastened to the head with a plastic weld through a center hole- Xacto blade trims off pretty easily.
                      • woodinville guy
                        • 188
                        • Cedar Park, TX
                        cool thanks, I use them. Those are the two on the bottom of the brush, right?
                        - Dave
                        • jdon
                          • Feb 2010
                          • 401
                          • Snoqualmie, Wash.
                          I don't know about other brands, but IIRC our Sonicares with the standard head have one magnet- it looks like two bars, but there's a thinner part at the bottom connecting the two- like a dado. There's a hole in the center of the "dado", through which it's attached to the plastic.
