Nice rolling workdesk
  • tommyt654
    • Nov 2008
    • 2334
    The HF coupons are available in Wood and Woodworkers Journal magazines ,The Lowes 10% off you'll have to get in a address change packet from the PostOffice
    • RangerRick
      • Jun 2011
      • 25
      • Mass.
      • bt3000
      Thanks Tommy, I will check it out.
      • tommyt654
        • Nov 2008
        • 2334
        RR, You use them as a competitors coupon
        • tommyt654
          • Nov 2008
          • 2334
          Here's the link to those Cree flashlights as well, great deal on these man they are powerful, The price drops to $5 when you place and order. I got 3 2packs and now have them all over the house, but what a blast cowtippin last night ,http://www.homedepot.com/webapp/wcs/...c0s671&cj=true
          • IWannabe
            • 33
            • MD
            can someone kindly post the UPC barcode numbers (12 digits) printed on the box? TIA!
            • tommyt654
              • Nov 2008
              • 2334
              My boxes are long gone, sorry. What exactly do you need them for.
                UPC code: 764053470073
                • woodturner
                  • Jun 2008
                  • 2049
                  • Western Pennsylvania
                  #23
                  If you bought one of these and haven't put it together yet, you may want to check the box to make sure it has all the rails. I had to go through three of them, all in factory sealed boxes, to find (or make) a complete one.
                  The two end straps can be slid off the ends, and the middle strap cut. The top of the box lifts off, and there should be four rails on the bottom, under the edge of the cabinet, two in the front and two in the back. In the top left drawer is a box, and the other four rails should be in that box at the back, along with two wheels. The top right drawer has another box with two more wheels and the hardware.
                  In the ones I found, one or both sets of the rails on the bottom of the box were missing.
                  • tommyt654
                    • Nov 2008
                    • 2334
                    #24
                    Never had a problem with mine everything was in both boxes, but thanks for the heads up as others might feel obliged to look furthur into it if they can even find any of these great tables left for sale
                      After fooling with enough HF items, I am experienced in looking EVERYWHERE!
                      • wlaims
                        • 30
                        • Seattle, Washington
                        • Ryobi BT3100 / Festool TS55
                        #26
                        I wish they had packed the content upside down. With the exception of the instructions, which is on the top of the box, laying the top of the box on the floor and cutting open the bottom of the box will give you access to the rails right away, as well as having the drawer box oriented the correct way for assembly of the legs.
                        • tommyt654
                          • Nov 2008
                          • 2334
                          #27
                          Actually I liked the way it was packaged, Took the top off giving me a place to dump all the styrofoam and extra pieces of cardboard(a lot). Took 1 piece of extra cardboard and layed it over the end of the bottom piece and lifted up the top unit on to its end and allowed it to sit on that cardboard while I removed all the rails from the bottom piece and then assembled the top end then spinning it around layed it back down to assemble the other end, all in a small area on my driveway.Then all In had to do after final assembly was place the bottom back onto the top slide 2 remaining plastic straps back on box and haul to the dump, easy peasy
