Dremel Trio Rotary Tool Kit 59.99
  • Mr__Bill
    • 2096
    • Tacoma, WA
    Saw this at WOOT for 59.99 most often it's 99.99 so it looks like a good price if you want one.
    Dremel Trio Rotary Tool Kit at WOOT
    This is for today, Tuesday the sixth.
    on the left coast
    • 22050
    fine print:
    "Note: The Dremel Trio uses only Trio accessories. Dremel rotary tool accessories are not compatible with the Trio tool"
      fine print:
      That was bad planning. Or, maybe good for the company so the accessories can't be swapped. It's likely that the accessories available for it cover a pretty good range of applications. For the money it seems like a good deal.
      • johnk
        • Feb 2009
        • 82
        Thanks for posting!
        • annunaki
          • Jan 2008
          • 610
          • White Springs, Florida
          • 21829, BT3100, 2-BT3000(15amp)
          Here is what I found on Amazon and posted on Woot-
          Here is an Amazon User's Opinion-
          Be aware that many of the products that show up in the "other things people who bought this have purchased" section do NOT fit this tool. Not good - this tool only uses special bis that fit in the 3/16 collet. It can't use normal dremel bits, nor normal router bits. So it is an underpowered baby router with a TINY selection of expensive special bits (that break easily). I like the handle and base design, and wanted to like the product - but the special bits will make it almost worthless.
          http://en.wikipedia.org/wiki/Fileodecahedron.gif
