Harbor Freight compressed air plumbing system $60
  • dewi1219
    • 307
    • Birmingham, AL
    Harbor Freight has a garage compressed air plumbing system, item number 66747, that is apparently a direct knockoff of the Rapidair system (Rapidair even has a comment about it on their website). It was discussed sometime back here. I have been planning to pick it up with one of the 20% off coupons, but I noticed recently that it had disappeared from the HF website. I called my local store today to see if it maybe had been discontinued. They still have them in stock, and the price is now $59.99. Regular price used to be ~$100 and this is the first time I've ever known it to be less than $79.99. It comes with 100 feet of air line, a manifold, and two outlets. You can't view it on the website any more but you can still access the product manual here.
    • 4715
    Rapidair's claim on their website is laughable!
    • BigguyZ
      • Jul 2006
      • 1818
      • Minneapolis, MN
      I didn't see any claim on their website, but definitely a cool product. I'll have to look for the HF item locally.
      • dewi1219
        • 307
        • Birmingham, AL
        Scroll to the bottom of this page.
        • BigguyZ
          • Jul 2006
          • 1818
          • Minneapolis, MN
          Ah.... the text wasn't visible for some reason. Probably my work's old browser. I had to highlight the text to find it....
          That is indeed rediculous.
            If they don't have it on their website, maybe it is discontinued and they are just selling off remaining stock.
            • wardprobst
              • 681
              • Wichita Falls, TX, USA.
              • Craftsman 22811
              What do you base your statement on? (not trying to be confrontational, just curious)
              DP
              www.wardprobst.com
              • tsbrewers
                • 207
                a buddy of mine used to sell the rapidair stuff, and he said it was great stuff, but expensive. Has anyone actually used the HF version?
                Brew
                • dewi1219
                  • 307
                  • Birmingham, AL
                  If you go to this thread and read posts #17 & #20, member "gnal41" used the system and also added a drop with parts from the Rapidair system (Rapidair sells components individually). Before the system disappeared off of the HF site, there were quite a few reviews, all of them favorable IIRC.
                  • BigguyZ
                    • Jul 2006
                    • 1818
                    • Minneapolis, MN
                    For $48, I almost picked up two sets. But I figured that 3 outlets running along my stationary bench are enough.
                    I haven't had a chance to play with it, but it looks cool.
                      • 4715
                      DP
                      Sorry Ward that it has taken me so long to explain.....What I mean is that I have known about the style of airline fittings for at least 15 years. I think it is a fair bet that Rapidair did not develop any of the technology they are selling in the kits. i think they possibly could be the first to market to this niche with a "system." HF seems to have capitalized on a good idea. A claim that their competitors item is poor quality based on price point just rings hollow to me. HF has enormous economies of scale working for them. Their overhead for marketing is a fraction of Rapidairs due to HF's marketing methods.
                      • wardprobst
                        • 681
                        • Craftsman 22811
                        No problem, I was just wondering. I run a lot of air tools and while I don't have the Rapidair, I have used a bunch of Harbor Freight fittings and had a lot of trouble with them leaking air. It's to the point that I won't use them anymore. I looked at the Rapidair and the machining seemed to be of higher quality. I ended up with 3/4 galvanized pipe mainly because I could add additional air volume with the long runs I had to make. I'm not trying to stir it up about Harbor Freight, I've bought some stuff there that other vendors sell for higher prices but I've learned to be really careful about what I buy.
                        Thanks for your reply,
                        Dale
                        www.wardprobst.com
                        • dewi1219
                          • 307
                          • Birmingham, AL
                          Dale
                          Dale,
                          When you say you've experienced leaks with the HF fittings, do you mean those included with the air line kit mentioned above or other fittings like the standard quick disconnects, etc.? I read quite a few reviews on the air line kit before it was removed from the HF website, and they all seemed to indicate that leaks were not a problem. I am wondering because I was planning on buying the system today and I have two concerns with it: 1) leaks, and 2) the size of the line being sufficient to support higher volume tools like a DA sander or HVLP gun (automotive type).
                          I would like to use galvanized pipe myself, but I have concerns about it leaking as well. I figured for $59, there wasn't much to lose with the HF kit.
                          • BigguyZ
                            • Jul 2006
                            • 1818
                            • Minneapolis, MN
                            I know for their quick-connect fittings, sometimes they don't seat/ fit properly, and then they can leak. But for simple elbows and such, I think your fine. You could always use locktite to help lock in/ seal the fittings, but that's not that necessary- teflon should work fine as well (I prefer the paste form, not the tape).
                            • woodturner
                              • Jun 2008
                              • 2049
                              • Western Pennsylvania
                              There are two types of quick disconnect fittings, and HF sells both. They are VERY similar in appearance. If the "industrial" and "automotive" fittings are mixed, they can leak. They will fit together in both combinations, they just won't fit well and may leak.
                              Halfway down the page on the following link is a good article on quick-connect couplers:
                              air connectors
                              There is "universal" style coupler that works with all three standard fitting types (ARO, industrial, and automotive).
                              FWIW, I have used a lot of HF fittings and have had no problems with leaks.
