Hitachi 23 NP35A Gauge Micro Pin Nailer - $77.34 FS @ Amazon
  • fgarvin
    • Oct 2009
    • 56
    I posted this over at SD too. I'll also ask the question here.
    Any body have any opinions on this one?
    When the PIN-100 dropped to $69 at HD, some members at HD stated the 1" max length on the PIN-100 was too short. So I've been looking for a deal on a Grex, but they are still 2 to 2.5x this price.
    Is 1-3/8" enough? Or do I really want to hold out for 2" Capacity of the Grex?
    I'm see myself mostly just doing edge trimming or tacking to hold pieces which even at 1" should be enough. I'm a beginning woodworker, so I'm sure I might be missing some scenarios that I haven't experienced or thought of yet, so I'd like some feedback to future proof my purchase.
    Thanks! Happy Holidays.
    • 22058
    pin nailers are used for small detailed projects where small pieces are tacked to other pieces and a lot of holding strength is not needed (often helped with glue to make a stronger joint). The benefit is in the headless nail making a nearly invisible hole making finishing easy while providing limited holding power (more for positioning while the glue is setting). so the pieces being nailed will be less than 1/2" thick usually.
    I'm thinking these kind of nailers are for use in doll furniture, small boxes, small toys, decorations, etc.
    So I think in general 1" nail length should be sufficient. certainly 1-3/8" capacity is not worth an extra 2x or more price for the little occasion to use it. Certainly a 23 ga pin of 1" or even 1-3/8" is probably not enough holding power to nail 3/4" material to anything else.
    • herb fellows
      • New York City
      They will go through 3/4" wood, so if you're trying to position wood of that size for gluing or whatever, the extra 3/16" helps a lot.
      Of course the value of it is up to you, based on your usage.
      I paid $100 for a 1 inch PC pin nailer. If I didn't already own that, I would definitely consider this at the price.
