Good deal on drum sander?
  • hcmthree11
    Handtools only
    • Nov 2009
    • 4
    Is $300 a good price on a Grizzly drum sander?
    http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_671wt_1141
    Short answer - yes. Drum sanders really command a high price.
    The only thing I'd caution you about that one is that it has closed ends like a planer. Most drum sanders have one open end, which allows you to turn a wide panel around and sand the whole thing. I wouldn't have much trouble with the 12" width, but if you plan to make larger pieces it could be inhibiting.
    • sweensdv
      • 2873
      • WI
      • Baileigh TS-1040P-50
      Your very first post and you provide a link to an eBay auction that isn't closed yet??? Salmon, Herring, Halibut and Cod also smell a little fishy.
      • Skaning
        • Nov 2010
        • 63
        I'd say it depends on your needs. A 12" sander is kinda like a 12" planer. It's does about the same thing albeit potentially with a better finish. Less chance of tearout on Knarly grain, and a lot slower. You can pull off 1/64 to 1/32 a pass on a planer. Probably half that on the sander.
        I've got a project that I want to surface about 1200 sq feet of T&G pine. Thank you I'm NOT going there with a ROS. So, I bought a used 16" grizzly drum sander for $350. The shop that had it used it for drawer fronts, too small for anything else. They finally sold it to get a larger one so they could do doors as well. I'm going to do 5 to 6" wide stuff 6 to 12 feet long so the 16" didn't bother me. I'd have been happy with the 12" actually because it's 110V. The 16" is 220V so I still have to rewire the job site.
        Remember too these puppies generate a lot of fine dust and a shop vac isn't gonna cut it. You will, at the least, make a trip to harbor freight for one of their low end dust collectors io deal with this. I know I will and my plan is to route it out the nearest window rather than bag it.
        All that said, $300 is a bit more than half of the current price new ($545 for the white one). I certainly would not pay much more than that and I'll suspect he isn't going to get a lot of traffic because it is the small one. If it fits someones needs perfectly he may get that for it. I'd watch it and if he gets some action, good for him, otherwise let it expire and if you still want it contact him and offer him $250 and see if he'll bite
        • hcmthree11
          Handtools only
          • Nov 2009
          • 4
          I understand your concern, but I am not selling the item listed on ebay, just wanted to some feedback from the group.
          • Cochese
            • Jun 2010
            • 1988
            Not too many spammers lurk for a year before posting. I'll withhold judgment.
              new $695, on sale for $528. Good price if it doesn't wind up in a bidding war at the end.
              • herb fellows
                • New York City
                You did see that this is local pick up only?
                As you didn't list your location on this site, have no idea where you are.
                • hcmthree11
                  Handtools only
                  • Nov 2009
                  • 4
                  It is actually local to me, about a 45 minute drive away from where I live in Virginia. Even with the limitations mentioned I am tempted, mostly because my Ridgid planer has been having trouble with tearout, even with fresh blades.
                    • 9568
                    On the planer issue, are you checking your feed direction? Grain direction matters a LOT in regards to tear out on planers and jointers... If you don't know what I am talking about, go to http://thewoodwhisperer.com/episode-...inters-jumpin/, Marc demos the proper way to do it with a jointer, a planer isn't a whole lot different...
                    FWIW, for $300.00, you can build a heck of a NICE 24" drum sander on the DIY approach. There are LOTS of documents out there on how to do it...
                    • hcmthree11
                      Handtools only
                      • Nov 2009
                      • 4
                      Well i went ahead and bought it. I will let everyone know how it works out! Thanks for the feedback.
