Ridgid Pro Jigsaw $81+ shipped
  • tommyt654
    • Nov 2008
    • 2334
    http://www.homedepot.com/webapp/wcs/...rderCalculate#
  • Uncle Hook
    • 314
    Thanks for posting this. I read the reviews and users complain about changing blades being a fussy process. I would love to hear comments on this from owners of this saw. I have a Grizzly Jigsaw that I like except for the blade changing process.
    • sweensdv
      • 2873
      • WI
      • Baileigh TS-1040P-50
      The Ridgid jigsaw is like a lot of other jigsaws in that when you first start to use it out of the box the blade locking mechanism can be rather tight. Because of this sometimes the blade will not seat all the way. All that is required though is just an extra little shove of the blade into the mechanism to ensure it's seated all the way. After using the jigsaw for awhile the blade locking mechanism gets worn in and installing the blades isn't a problem any longer. I wouldn't consider this a negative at all as eventually when the newness wears off the problem does goes away.
      • conwaygolfer
        • Jun 2008
        • 371
        • Conway, SC.
        When I follow the link - it says $149.00 plus shipping.
        Conwaygolfer
        • sweensdv
          • 2873
          • WI
          Scroll down to the bottom of the linked page.
          • toolguy1000
            • Mar 2009
            • 1142
            • westchester cnty, ny
            in our HDs, they're $69, down from $139.
            • tommyt654
              • Nov 2008
              • 2334
              Great send some pics so I can get a price match,Thanks
              • r_wright1
                Handtools only
                • Jan 2010
                • 4
                To get the discount, use coupon code SDCQB.
                • toolguy1000
                  • Mar 2009
                  • 1142
                  if i find myself in the stores before they are all gone, it would be my pleasure.
                  • tommyt654
                    • Nov 2008
                    • 2334
                    Ha,Your a toolguy of course you,ll be their just like they will
                    • toolguy1000
                      • Mar 2009
                      • 1142
                      as requested
                      here ya go:
                      • Andrew Benedetto
                        • 1071
                        • SoCal, USA
                        I have the cordless, same design The blade need to be firmly pressed into the shaft and pressure kept on the spring while releasing the clamp lever, if you do not it will be loose. a good saw considering the price and made in China, not as good as my Swiss Bosch over 15 y.o.
                        Andrew
                        • tommyt654
                          • Nov 2008
                          • 2334
                          Thanks,Saves me a trip,Looks like there,s plenty of them,Must not be a lot of woodworkers there.
                          • Bear
                            • Aug 2009
                            • 8
                            Jigsaw
                            I found one in SW Omaha NE Display for 50.00 no bag only onein area. Also got free shipping and some extra blades.
                            Bear
