Saw this while browsing through the Tools & Home Improvement section of Amazon Gold Box Deals. Some of the bits start @ $4.99 and saw some raised panel ones for $9.99 ordered me a few.
Those raised panel bits for $10 are a really nice deal. They're a little smaller than the standard 3-1/2" panel raisers, but a size I've often wished I had.
...They must match the raised panel bit perfectly, right? Thanks.
Not really...the style and rail set must match each other perfectly in order for the cope and stick joint to fit well, but the panel only needs to fit in the slot that the rail and style set makes....and that's a floating panel so fit isn't precise. Pretty much mix and match with the panel raising bit.
Thanks for that. Got both panel raising bits, two slot cutters and a mortising and dovetail bit for under $40 shipped. Can't beat that, and will help fill out my new table nicely.
Not sure about the quality of Amazon service ... I ordered 3 items, they claim to have shipped one item last Thursday (but I haven't seen it yet), one item yesterday, and this morning I got an email telling me the third item was out of stock at their supplier so they canceled that item from my order. (Naturally, it was the door-lip bit which I actually planned to use first!)
So I went to the site. The door-lip bit still shows as available so I tried buying it again, signed up for a free trial of "Prime" to get the 2-day shipping.
Will it miraculously turn up? Does their ordering system talk to their stock control system? Gosh, the excitement ...
There should be plenty of this bit in stock.
I am curious what type of the cabinet door this bit can be used on. Is it European style frame-less door? And do you route the whole edge (1 side) or just a small section?
As to the bits on sales this time, I am wonder if the qualities are good after a closer look of the bits I received since I found that:
1. On the label of all boxes, the "Made in Italy..." was covered with correction tape. But on the bit shank it says "made in Italy". It is suspicious.
2. On the raised panel bit, around the edge where they weld the cutting blade on, I can see uneven wielding spots (or even small tiny holes). I don't know if that is common for this kind of large bit since I never own one before.
I believe if the item itself says "Made in Italy", then to comply with US law it must have been made in Italy. (That would be okay with me.)
Sort of. If a product is labelled "made in USA", it must be "all or substantially made in the US":
According to the Commission’s 1997 U.S. Origin Claims Enforcement Policy Statement, for a product to be advertised or labeled as “Made in U.S.A,” the product must be “all or virtually all” made in the United States – that is, all significant parts and processing must be of U.S. origin, and the product should contain no (or negligible) foreign content. http://www.ftc.gov/opa/2009/07/evs.shtm
That's why US brand cars are not advertised as "made in USA" - they don't meet this requirement. Ironically, only some foreign brand cars meet this requirement.
The FTC imposes less stringent standards for items made in other countries - so a "made in Italy" could be made almost anywhere, as long as 51% or more of the value is added in Italy.
