Link Belt deal
  • tommyt654
    • Nov 2008
    • 2334
    Link Belt deal
    Harbor Freight has dropped their price.http://www.harborfreight.com/cpi/cta...emnumber=43771
  • BrazosJake
    • 1148
    • Benbrook, TX.
    • Emerson-built Craftsman
    That's also a foot longer than most link belts.
      • 9560
      I've got them on my band saw, they work really well... I want to build a wide drum sander, I could use another one of those...
      • Prax
        • Dec 2009
        • 16
        • Perry, GA
        • Craftsman 10" Contractor Series
        Do these belts really work on cutting down the vibration? I would greatly appreciate your experience on these. I would really like one for my TS. Thanks.
        LOML, sawdust and beer - what more could a man ask for?
        • sscherin
          • 772
          • Kennewick, WA, USA.
          I have them on my Lathe and drill press.. They work great..
          The HF belts are 1/2"w and made by Jason Industrial..
          A US made product at HF? who would have thought of that.
          If you need other sizes they make 3/8, 1/2, 5/8 and 7/8 belts.
          The other sizes can be found on Ebay easy enough.
          William's Law--
          • BrazosJake
            • 1148
            • Benbrook, TX.
            Yes. Regular rubber v-belts will take a set, that is, they get stuck in the shape they're sitting in, causing a little bounce as they run over the pulleys. Link belts are like a chain, each link hinges with the next, so it remains flexible.
              • 9560
              Depends on what is causing your vibration... But yes, if you have a V belt that is, well... has a bump to it like many do, this will cure that...
              I like that they grab better than a V belt. The stock V belt on my HF band saw slipped, a LOT... This thing never slips...
              • WayneJ
                • 785
                I have the H.F. belt on my contractor table saw for about two years and never a problem with it . With the old belt it would vibrate when cold till it ran about five minutes.
                Wayne
                Wayne J
                • exodus
                  • Sep 2008
                  • 6
                  • Weatherford, TX
                  • Powermatic 64A
                  I put one on my TS, huge improvement!! Took the vibration out completely. I even went as far as doing the start up/shut down nickel test with no problems.
